Twisted Bravo I Drive Spline
![Question](/forums/images/icons/icon5.gif)
I have a 97' Bravo I that had a drive shaft spline twist just in front of the prop. It is a mild twist that has not gotten worse since I owned the boat(2 yrs.) The shaft is not bent, looks true, and does not vibrate. Boat is a 25' Eliminator Eagle XP, 502 Mag, Procharger M-3 recently installed. Am I being stupid by not having the shaft replaced, or is this something I can live with? Noticed that Cobra had some upgraded units for sale. If this needs to be replaced how much should I expect to pay for a shaft? Thanks in advance.
Charter Member # 545
Have seen them twist so bad you have to cut them to get the prop off shaft. Not good!! Also with your procharger if your propshaft brakes under boost, their is a possiblity of alot more getting damaged if motor over revs.
I would replace it. Once metal deforms, it looses much of its originally designed physical properties. That is, it's weaker, much weaker. Go to Mercruiserparts.com for an exploded view and price. Very convienient web site.
BT
BT
![Cool](/forums/images/smilies/cool.gif)
diggerman
09-03-2006 09:22 PM
