Rocker Arm Problems
Hello Guys,
Kaama is right about checking the rocker arms. I have had problems with Crane Gold with fewer problems with Harland Sharp, much better results with Crower and Comp Cams Stainless rockers. If you have a lubrication problem, nothing will live. Check the oiling!!!
I have had several stud failures. A good aftermarket set like ARP or similar will help. I also try to run a stud girdle on ANY roller cam. If you place a dial indicator on the stud and rotate the engine, the stud will flex as the valve goes through it's motion.
If you use a strobe light set up, you can see more motion than a Hula dance!!!
![Talking](/forums/images/icons/icon10.gif)
Thanks guys...
Yes, they are the Crane Golds.
I'll check the flow of the oil to start... That's got to be tricky deal - moving the crank and spinning the oil pump.
Bob - I found those also and would be interested in the group pricing - I what red though...
Red Racer
Red Racer
