Lets Build the Perfect 540 >
Old 05-21-2004, 09:04 AM
  #61
Charter Member #232
Audiofn's Avatar
Default Re: Lets Build the Perfect 540
TTT for Andy Buzz
Put your best foot forward!
Audiofn is offline
Old 05-21-2004, 09:05 AM
  #62
Charter Member #232
Audiofn's Avatar
Andy you also asked me for a drive recommendation. I would suggest a look at the Konrads. They make a addaptor set up to convert over your bravo's
Jon
Audiofn is offline
Old 05-21-2004, 09:33 AM
  #63
robyw1's Avatar
Originally Posted by mcollinstn
cam selection has everything to do with compression ratio.
A "planned" NA motor needs more compression and more cam.
A "planned" blower motor needs low compression and different cam.
Are we looking to build the best "do-anything" motor with big power and lifespan while remaining on a budget?
I think it needs to be port-fuel-injected (Cutler style).
Gapless top rings with low tension oil rings.
.040" squish height (zero deck).
hydraulic roller using extended length factory style lifters (no link bars).
Crank trigger ignition.
crank scraper and windage screen.
Polished and shotpeened rods with ARP bolts.
Head studs.
Valvespring retainers with oil holes for springs (a-la Milodon).
Fluidampr
Good balance job.
There: that's my list of "adds".
Mcollinstn, Are the zero-gap-top rings durable enough to handle boost and possibly a little detonation should it happen to him? I have been a little out of the loop lately but I have always thought in a sustained boost/RPM engine that zero-gap-seconds would be perferable especially if the piston had a high silicon content. Am I wrong about this?
Roby
robyw1 is offline
Old 05-21-2004, 11:04 AM
  #64
cstraub69@comcast
If you want good leak numbers, by all means run the gapless stuff. If you want more power, open the second ring up to 30% to 40% more then the top and make more power at mid to upper rpm. Ring flutter kills power.
Chris
CAFE
4
11-15-2005 09:44 AM
vegas daytona
8
10-26-2005 06:46 PM
Dock Holiday
Baja
16
02-25-2003 05:00 PM
dyno
43
01-20-2003 05:44 PM
Quick Reply: Lets Build the Perfect 540
