Timming
If your compression is below 9-1 and your running marine pump gas~89, you can go as high as 36 but be safe and go 34. If your compression is higher you would want to go 32 or less. There are many other factors involved though.
You guys are right!!
The only way to get it right on any combination is to do plug chercks. If you do not know how to read plugs, find someone who does and consult with them. If notheing else, pm me and I will try to help. The best AVERAGE TIMING curve to start with is about what DaveF suggested, but do a SHORT run and check plugs!! This is a time consuming and boring task, but totally necessary!!
Have a great day!!
Have a great day!!
THANKS FOR THE INFO GUYS,THE MOTORS ARE STOCK ,IM RUNNING 91 OCTANE,I SET THE TIMMING AT 34 TOTAL AT 3400RPM TO START OFF WITH.CHECKING PLUGS WILL BE THE NEXT STEP THERE JUST A REAL PAYNE TO GET TO.
