Help me pick the right cam?
Back4More,
Reguarding intercoolers, they don't make much power at low boost, but they do make a difference when you string one out!
Be sure to keep up with the plugs.
Your Isky cam is pretty good, I like the intake, but would recommend about 264* on the exhaust on about 144-115 lobe spread installed striaght up. I made 30 more on the dyno with a similar solid from Isky than any other cam we ran in that test. We got 1007 at 6,200. Non of the other camsj, even the ones from Crane, Comp and Ultradyn and Isky made over 960 in this application. That is a 565 cruiser motor on an HONEST dyno.
