Mark IV crank in Gen V block? Possible??
I believe I read somewhere that a Mark IV crank can be used ib a Gen V block thru use of an adapter??? Is this true? If so, where/what is a source & part # of the adapter?????
Also, looking for a std bore Mark IV or Gen V engine (either-, crank used) or block , crank, pan, heads (if gen V) .
This setup is what I have. My engine builder ordered it when he assembled short block. It is 2 pieces of alum. that go where the rear main seal is. New block wants a 1 piece rear seal where crank is for 2 piece seal. Have had for 3 years now & no oil leak thru rear main seal. If you need I can call & see where he got it.
Blown- Here is what I found out. Looking at picture it looks like the part # 8736
http://www.flatlanderracing.com/stefsextras2.html
Part#8735 or 36 $87.95
I will try I see where mine was gotten from.
