stern drive help
WooooW, duker, you are going to get alot of differing answers on this one. Welcome to the board!!!!!!
This is definitely the place to find out the information you are looking for.
I am running a XR upper with an Imco lower and so far no breakage, but you are running alot more power than I am. There are a number of drives out there that people use with that much power, but drive failure is iminent if you don't treat it right, and maintain it properly. Here are some Bravo-XR, Imco, B-max, Pulse drives. There was a couple of treads in the last month about the pulse drives that are very interesting. Just click on Forums/Boards on the top and click search. Then type in pulse or anything you want to search for, and you have hours of fine reading. Maybe the Bravo Shop, BAM Marine, or sterndrivespec will see this and make some suggestions.
Welcome to the board.
![Cool](/forums/images/smilies/cool.gif)
I hate the winter!!
I think that you should be looking into either a surface drive ( Pulse or Arneson ) or a #6. 900 h.p. is alot of power for a Bravo or even a B-Max. I am sure that the B-Max would hold up for a while, but it would depend on how you treat it. Also, I don't know how you would get a drive on that boat that required a transmission without MAJOR modifications. Good Luck and be safe....
Gone Fishin'
In the General Discussion section is a thread called "B-Max will be at Chicago and Cleveland" or something really close to that. Contact Wild Thing Taz, (Ron) and he can answer all your questions about the B-max. I talked to him for a while at the Chicago show. Informative gentleman he is.
I'll see if I can post a link.
Try this link:
http://www.offshoreonly.com/forums/s...threadid=39424
![Smilie](/forums/images/smilies/smile.gif)
Try this link:
