Alluminum Or Cast Heads Pros & Cons >
Old 01-23-2003, 01:28 PM
Back4More's Avatar
I was told that you could run about a pound more boost thru Aluminum heads and not worry about that "D" thing.
BTW...Whats the static CR and size carbs on that 10-71/572?
Back4More is offline
Old 01-23-2003, 01:36 PM
blown1500
That "D" thing is very important, but you can run more boost with aluminum. I did 2 otherwise identical 565's a while back to prove the point. Same Littlefield, cams, compression, heads,..........
One had "D" pistons, the other round depressions. It took 2# more on the round dish to equal the "D". In the boat, the "D" uses less gas, even with the same boost. Turbulence in the combustion chamber is the reason. You must also have about .040" deck total, including the gasket for best performance.
Those particular engines made 1,007hp and 1,006hp at 9 and 11psi, 6,200rpm.
Old 01-23-2003, 01:45 PM
Back4More's Avatar
Is that considered the "quench height" I read about but never understood?
Old 01-23-2003, 02:18 PM
blown1500
Yep!!
Back4More, that is correct. If you can get one, the Keith Black Pistons catalogue has some great info on this and several other topics. If you can't find one, post or pm and I'll try to show this part.
Old 01-23-2003, 09:14 PM
fountainracin42
Aluminum heads flow better than cast...period.... There is no way you can get a cast head to perform like a aluminum head...if you can please let me know and I will notify every race team crew chief with the NEW CAST PERFORMANCE info!!!! I gained huge horsepower on my 572 with aluminum heads!!
Old 01-23-2003, 09:25 PM
blown1500
Fountainracin42,
You can get aluminum in more configurations than iron. If really big ports is what you need, there are no comparable irons available.
If you need a head that is of comparable port volume to an aluminum head, the facts stated above are factual. Any good porter can make a well designed iron head flow about the same as a comparable aluminum one. He might not like the time needed or the iron filings, but it is commonly done. Ask some good porters. JimV maybe? Try calling World Products. They make iron and aluminum versions of some BBC heads.
Old 01-24-2003, 10:20 AM
Fountainracin42
Thanks for your input I appritiate it. I am calling them today to give my engine colours and find out whose heads he is using
be cool
WILD ONE is offline
Old 01-24-2003, 11:30 AM
JimV's Avatar
Wink
It's not so much the matieral it's the patterns. For example World Products have not changed their patterns in years on the iron heads. The bowls are shallow in the exhaust and intake ports. The later pro one heads have better ports flowing more air out of the box because of design. Also the aluminum heads are thicker allowing more room for porting. As far as the difference in one being more smooth than the other, (or parasitic drag) accounts for only two percent max air flow loss on lets say the wall or floor of a port. The rules change at the turns and near the seats.
JimV is offline
Old 01-24-2003, 11:39 AM
THANKS JIMV
THATS BASICLY WHAT THEY ARE TELLING ME THE ALLUMINUM IS PORTED BETTER AND POLLISHED CLEANER THAN THE STOCK CAST UNITS
WILD ONE is offline
BOATMAN302
10
01-25-2008 10:46 AM
rangerrick63
10-04-2007 11:49 AM
selfmade
4
03-30-2006 08:49 PM
berman58
01-12-2006 07:47 AM
Brian Crane
10-07-2002 02:33 PM
Quick Reply: Alluminum Or Cast Heads Pros & Cons
