Roller Rockers, are the worth the cost and effort??
As mentioned by a few others, you will almost have no choice but to use roller rocker arms when going to a higher lift cam. GM once made their stamped steel rocker arm called "long slot" rocker arms that took on a higher lift cam, but I do not remember what its lift limits are. I tend to believe the roller style rocker arms have advantages over the stamped steel ones as blown1500 has mentioned---ratios are more accurate too. Just look around and you'll see roller rocker arms on all performance oriented engines.
The new Jesel Sportsman's Series shaft mount roller rocker arms for about $695 as advertised I have heard have failed in some cases, but I don't know how extreme of case they failed under. I was just told to use the next grade up that Jesel makes.
Charter Member #655
WOW Mark!!!!you want him to drop $700 on a set of rockers on a stock Mag motor????you can buy Harland sharp or Crane Golds for a little over $200 and they work Great!!!!
If your boat has a sail do you ride a horse to the ramp?
Dyno,
I have had less problems with Harland Sharp than Crane Gold and they cost less than $200 in the mail order catalogues. We try to go for stainless rockers like Crower or Comp. They just don't break. Shaft rockers are the ticket, but think about whether they are necessary to justify the cost.
Like KAAMA says, the ratios are better with roller rockers. The Comp roller tip Magnums have good ratio also. The general improvement in performance between stock and roller is true ratio. The stamped rockers, no matter who made them-GM, Ford, Manley............ they are not true and not consistent. A 1.7 rocker is never 1.7 but something less. 1.5 Chevy SB rockers I have tested were sometimes as low as 1.42:1.
If you burn a rocker on a stock application, it's a lubrication problem. I think Crane makes "Kool Nuts" to deflect the oil where it needs to go. This works.
Re: Roller Rockers
Thanks for the info,
The reason I was considering it, was I have low compression, which I have to check again to see if its valves or rings. But if its valves, and I have to take the heads off, I figuired I might as well do the roller rockers, only IF it makes much sence. And money these days IS an issue, stock market!! Making it last longer would be nice.
Would greatly appreciate your input.
Thanks in advance
Richard "2Slow"
My Original question:
Hi,
I have a stock 454 Magnum, carb model with CMI headers on a 21
Eliminator.
Wondering if converting the heads to roller rockers is worth the cost and
effort.
Most of my driving is going half throttle, and a couple of full throttle poker
runs.
Thank you in advance
Thanks in advance
Richard "2Slow"
Originally posted by blown1500
Hello, Guys,
I agree with Griff. The rolller rockers will help some things, like a tiny hp gain unless you get 1.8 rockers or something, but even that is relatively small increase on your motor. Roller rockers do help valve guide life, small help with oil temp. If you need rockers for some other reason-wear, breakage, etc., I would look at Comp roller tilp Magnums. They will be maybe 10hp and relatively cheap. But not worth the change unless you need rockers.
I'd save the money for a cam to go with the rockers, or even just a cam!!
Hello, Guys,
Hi,
Eliminator.
effort.
runs.
Originally posted by mcollinstn
If you have the heads sitting on the bench then, yes, I'd do it.
zimm17
5
05-25-2007 09:24 PM
