Alpha L/H- Who has experience?
#41
Neno the mind boggler
twinn29- that would be great. im suprised arizona didnt have anything. after all the merc 500efi system is one of their's. i wonder who makes the system for the 377 scorpion . i think that is a multi point injection system. thanks
sonic30ss- what kind of injection is on your 320efi's
08 OPA High Points Champion
#43
Dave, My injection system is a Mercury Racing MPI set up. I spent a great deal of time researching it with no help from Merc racing they have"no prints or specs left". Turns out it is a batch fire system, using Porche injectors from a 85-87 928s 4.7l.
I took the manifolds complete with injectors,fuel rails and regulators to Marrin Fuel injection(www.injector.com), who flowed my stock injectors to figure out what we could use for new/upgraded set up.
Not bigger just more modern(better windings and spray pattern).
They did a great job on the manifolds, and he personally garrenteed the work, if it does'nt work he'll come on board to fix it. He sets up IMSA, SCCA injection systems , as well as doing, some OEM work that they(oem) will never tell you about! He is also a boater.
The manifolds are Two piece tunnel rams with a single 3.75'' butterfly as the top portion, pointing towards the bow. When I saw this set up I knew I HAD to get this boat, It is a very unique set up the only offerd in 87,88,89. I was told that in 87 it was a14,000.00 optional upgrade. The colors also match my bike and car!
I'll post pic on Mon. it's in my work puter.
Joe
Joe
#44
twinn29,
No props lying around, just the 23 Mirage's that I'm using. I am either going to send them to Mercury to be finished or go to a smaller Rev 4. I need more rpm's.
#45
Sutphil- Im running 23p props also but they are Merc stainless Quicksilver props # 4816320A4 23p.In a typical configuration I run (1/2 to 3/4 tank of gas, 4 people, hot day etc) I only see 4200rpm, I'd like to see about 4800. I was thinking about a set of 19p Mirage Pluses, I know they are larger diameter than my props. What rpm are you seeing?
#46
twinn29,
I am running about the same rpm's as you are. I have heard that the Rev 4 has many positive points - quick acceleration, great hold, better transom lift (I hardly use any trim) and a much faster mid range cruise speed. I don't know your fuel tank size, (mine is about 400 litres) but that's a lot of gas for two little motors.
I'll keep you posted when I change/test props.
#47
Originally posted by BajaRunner
When is the alpha XR coming out
You havent heard of the Alpha XR?? I can sell you one.... Due to the high performance needs of the drive... you will need to re do a bunch of stuff to install the Bravo 1 with different stickers aaah, back space isnt working, i mean the Alpha XR.
#48
Glass dave here is the pic of boat, car and bike.
There are better pic of car on www.teamsofaking.com
#49
OK lets try again
#50
AHHHHHH Now I'm getting pissed!
I guess I'm having trouble sizing
