View Poll Results: Solid white or splatter paint in bilge?
Solid white!
73
73.00%
White with purple & gray splatter paint
21
21.00%
Some other paint scheme
6
6.00%
Voters: 100. You may not vote on this poll
Bilge - Splatter Paint or Not?
I vote for Cher....or maybe Britney
I have always belived that CLEAN IS MEAN I mean if its a stocker then splatter would look good. It would spiffen up the presentation (A stock common motor). It you have something you keep clean and is different and definitley not stock then I belive you want a clean compartment that in no way makes you look away from what it is you are presenting YOUR MOTOR! The ability to clean it and keep clean then is the pressing issue..If you spit and polish your motor like most of us then the ability to clean and not show the little stuff becomes a time saver. I like Audio and Top's choices. Mine is medium gray with diamond plate on both sides of the motor. But Cher would do in a pinch
I am at the same point as Jeff... ready to paint bilge. Was going to do white, but would like to see what the grey looks like. Anyone have any pictures with the bilge done in light grey? I went to 2 places to get the interlux bilge kote white, and all they carried was grey, so I am still open.
BT
BT
West Marine & Interlux quit making or handling the light grey bilgekote. They do have the medium grey (also the white is in the catalogue & they will order it for you. You want the store to order it as it is a "hazardous material" & the store eats the cost there. Just mix the white in the grey 'til you get the color you want..... it's the only way. For the side walls you can use Rustoleum enamel. After it hardens, it is resistant to petroleum products, just not as good as the bilgekote stuff.
