Trim Cylinder Bushings
I am curious if there are any aftermarket bushings to fit the trim cylinders on a Bravo outdrive. With the introduction of urethane bushings for other performance applications, I didn't know if they were available or even considered for a trim cylinder mounting bushing.
Mine are worn and must be replaced.
Thanks, Russ
Thanks, Russ
Official OSO boat whore
CPPerfomance has them. I used them on my boat. In a very short time the bright red faded and developed a chalky appearance. I also believe that the rubber is actually softer than mercs. I won't be making the same mistake again.
