Cat props
Cord,I run a 25 daytona 2 step with a 500efi and bravo 28 stock through 1.5 gears at 5100 rpm. It runs 84mph light with this set up. Never broke a shaft or a blade but gear sets..well. I tried a hydro and the boat was a bear to plane off. Looked at a lot of clouds waitin to come over the hump. Tried a mirage plus 30 and it almost wouldn't plane but picked up 1.2 mph on top. The drive surfaces all the time so I surmise thats why I break gear sets too often. Actually just came across a preproduction blackhawk drive through a connection at Mercury's training school last week( major deal ) and found a set of 29 and a set of 31 lab props for it so as soon as the ice melts(maybe by April this year) I will be doing some testing.
Official OSO boat whore
Air-if you prop it right, you should be into the low 90's with the BH. Would love to get into one, but I just havn't been able to get a deal to happen. Please keep me up to date with your testing!
Yea, I knew you were going to call me on it. Everytime I try to edit a post the computer crashes, so I wasn't going to chase after that little omision.
CORD,26 FT CAT 840 HP IMCO DRIVE 1.36 GEAR VERY CONSERVATIVE X-DEM PROP SHAFT ABOUT EVEN WITH BOTTOM CENTER SPONSON 32 4 BLADE BRAVO STOCK RUNS 108 AT 6K RPM TRIED HYDRO 30 5 BLADE BITES HARD-A LITTLE HARDER TO PLANE NO SPEED INCREASE BUT FEELS MUCH LOOSER-MORE STERN LIFT DIDNT LIKE IT..WANNA TRY 32 LAB 4 BLADE
