buy XR's or upgrade B1's?
I found pictures on some website that showed the ITS system. Looks cool. BAM also shows them on his parts lookup. Seems like the top cap was $185 and the back cap was $265 (don't know why the back cap was so much).
MC ,
I guess I thought you wear paying $9000, I was reading without thinking.
I would agree and buy the XR's then have Billet do a few upgrades on them. Like his bearing kits and the upper cap.
Rear Cover Assembly XR std #12717A1 List $232.25 Bam $198.12
Rear Cover Assembly ITS #840839T1 List $195.05 Bam $166.42
Rear Cover Stud #16-57932 (3/8-24 x 1.75" SS) List $4.90 Bam $4.78 (2 required)
Top Cap (Cover Assembly) XR std #92068A12 List $207.05 Bam $176.67
Top Cap (Cover Assembly) ITS #840838T1 List $263.50 Bam $224.87
Top Cap Stud #16-840851 List $14.05 Bam $13.69 (4 required)
75832T1 U joint std List $49.95 Bam $46.65
862132T U joint XR List $115.95 Bam $98.97
Yeah, Kaama, but Gadgets is talking about a new ITS top cap that is set up with two extra bolt holes to secure it to the new ITS rear cap for added holding power.
I'm not sure that the extra bolts will do much unless you want to use the lugs on the top cap and back cap to attach a tie bar. If you were to do that, the extra bolts would add rigidity to the REAR cap I think.
But one thing's for sure - they won't HURT.
