Oil Pump for Gen 6 502
Where and what part number for a Gen 6 oil pump? I want to use the same one Mercury uses in the Gen 6 but I am curious if there is a less expensive source for these.
Tim T.
Tim T.
Charter Member #30
Thanks I wanted to order it today and decided on the MV77HV.
I also decided to use the old pickup since I already have a brace welded to it. I will have to break the weld at the pump that is why I wanted to know the pickup lenth in case I had to go with plan B.
So I can assume that the oil pan on this motor is the same size pan that is on a truck (like a suburban with a 454).
I have Steps & Bubbles!
