Fuel Pressure&Oil temp Sensor
I need the board experts opinion on putting my sensors for Fuel pressure and Oil temp. Engines are 2000 502MAG/MPI's.
Thanks in advance for your expertise.
Remove the schrader valve at the
end of the fuel rail (front of engine)
install the fuel pressure sender there.
Oil temp sender:
there's an unused plug above the
oil filter/ adapter pad,( thats where mine
are) remove plug, install sender,
these aren't very fun to get to
though.(long arms and contortionist skills
are helpful)
Hope this helps.
jt
Oil temp sender:
are helpful)
Hope this helps.
jt
Thanks jt I do have long arms the contortion thing I'll let you know how it goes.
Schrader valve #2 here?
Originally posted by CAP071
My co-worker walked in and said "What are you staring at ? "
I hurt my tounge
I hurt my tounge
Item # 4 is what you want to
remove, your sender should
thread right into item # 3
good luck.
jt
good luck.
jt
cloudmaster_321
Do It Yourself, Boating on a Budget
2
10-19-2008 07:14 PM
