Lifter noise and oil weight/qty?? >
Old 04-14-2003, 03:36 PM
Budman's Avatar
Location: Kentucky - where the women are so fast we have to put a governor on 'em!!
Cam, lifters, rockers, valves, springs, etc., are all brand new. Only thing not new are the pushrods, and they only ran for two seasons, I believe.
Budman is offline
Old 04-14-2003, 05:40 PM
OK, Plan is to change oil as it got a little milky from running at idle 20 minutes with no water temp. Adjustment is at 1 turn on #1 in/ex and 3 ex. Run it below 3200 for 5 minutes or so check plugs ( new blower and Nickerson carb) and if all is well repeat several times. Then back them down to 1/2 and tighten till they are quite. I am betting that will be quite at a 1/2 or 3/4. I suspect assembly lube etc. was stopping up 1 in/ex and 3 ex.
BadDog is offline
Old 04-14-2003, 06:34 PM
bobby daniels
It just could be push rods seating and making a little noise
alecsammy
15
05-04-2008 08:11 PM
alecsammy
4
03-17-2008 09:30 AM
kaamacat
19
04-28-2004 01:25 PM
blue thunder
11
07-24-2003 07:50 PM
HOUSTONPROP
12-14-2002 07:26 PM
Quick Reply: Lifter noise and oil weight/qty??
