Crossovers
I've been reading your stuff for months,it's all Great,first time I posted, here goes....I know they say that a Alpha drive water pump will not support a small blocks cooling at idle. Is this because of the restriction from the thermostat? and if it is is it possible to use the manifolds to pre-heat the water first then go through the engine thus eliminating the thermostat? The reason I ask is I have my dad's old crackerbox, 283 small block chevy and that is how it is plumbed. I noticed the other day that the neo-vane pump on it dosn't look any bigger than the one in the drive? I've been thinking about this for days, thanks in advance!
Welcome to the board first.
I have seen BBC ran off alpha water pumps before so I do not see a problem with a SBC. You could use the manifolds to preheat your water but most run a restrictive orifice also to keep water pressure at an acceptable level. Crackerbox that has to be a blast to drive!
![Cool](/forums/images/smilies/cool.gif)
Thanx guys! I am going to try it. The crackerbox is a blast, my uncle built it in 53 and its been in the family ever since. Also I heard there is a impeller for the outdrives that is better than the rest?
