Houston Propeller RULES!!!!!!!!!
Den
Hey ,it was good talking to you on the horn Yesterday.
Thanks for placing your order and we will call you when the prop arrive here at our shop,Thanks again for the Business.
WHEN YOU WANT RESULT'S SEE HOUSTON PROPELLER SERVICE ,DELIVERING SPEED FOR YOUR BOAT.
281-580-PROP( 7767)
281-580-PROP( 7767)
EXPERIMENTING ON
That's how we came up with the ACCLERATOR,BY TRIAL AND ERROR AND TESTING.
SEND YOUR BRAVO-ONE in and we and twist and tweak it around ,I,am sure we can get the bow to lift better than it is.
changing pitch/and rake
Sutphen 30, we can change the pitch 2" up or down as well we can increase or decrease blade rake angle.
which will result in more or less bow lift depending on what we want,in your case more by adding rake and cup and would also have to redece the dia"/this will make it lift and pull hard rpms through midrange accleration for great top end speeds and bow lift resulting in reduced dragand a mush faster boat.
Darin
Darin
Darin,
Just spoke with Kim to say that I received the props and they are in perfect condition. They are now residing in on the top shelf of our master bedroom closet where no harm will come to them! It is too bad I will not be able to run 'em for another four months...maybe I should move to Houston!! The finished product is a thing of beauty, thanks again. I will give you a report in the spring when we are back in action. You and Kim have a great holiday and a happy and healthy new year.
Regards,
Gary and Ellen
Regards,
Gary and Ellen
gferdon/Happy Holidays
Kim told me you called and sorry Imissed you.
Thanks so much for the Business and tell your friends,That is our BEST ADVERTISING.
A HAPPY CUSTOMER,THAT'S WHAT IT'S ALL ABOUT.
HAPPY HOILDAYS TO YOU AND YOUR FAMILY
DARIN,& KIM
DARIN,& KIM
