Aftermarket Pulleys & Scat Crank?
Have a 383 with a Scat one-piece seal crankshaft. Last spring I tried various combinations of aftermarket pulleys for this setup and was unable to get proper alignment due to the Scat crank snout being shorter than normal.
Anybody have any experience with the Scat crank and what pulleys will line up right on this?
Can't spacer the crank pulley out as the snout only has so much meat.
