Help build my motors
#41
The only Lightnings at $1400 a set will be used as far as I know from shopping around. Lightnings are great headers but they are going to be $2500 retail! I managed to buy two lightly used pair for about $1100 apiece, and I was lucky I think. Why not go back to the seller and determine exactly what you have engine wise? As some have said the block numbers do not mean a thing if they have been remanufactured. Someone should know what is in them. As far as value received for money spent goes, you definitely need headers, not manifolds, and buy some K&N intakes/flame arrestors to flow as much air in as the headers can flow exhaust out. Have you checked to see if you have roller rockers as opposed to stock rockers? This might give you a clue as to what these blocks really are. Let me know if I can give you any other help. Bob.
#43
330s or 440s
BUY them! Now. Bob. Seriously, I would go back to this seller with the sales agrrement, there is one right, that specifies the 440s and demand that he stand up and do the right thing. NY has some pretty tough fraud laws don't they?
If you indeed have 330s, you are going to gain a very small amount of horsepower from headers according to Lightning, but still you will be much better off than w/o them, and you certainly can not use the log manifolds that you pictured. Some K&N flame arrestors at $80 apiece or so will help a little still. Good luck.
#44
Well it was a word of mouth agreement, So i don't have a leg to stand on, and i don't think he knew what they were.... he was told they were 440's from the guy he bought the boat from.... such is life i guess.... the the intake side of the heads looks bigger than the small peanut ports, and it supposedly has a fatter than stock cam, so we will see i guess..... i'll buy the headers now , and the flame arresters, and see what the boat does, i can reuse these parts again so its not a waste...
Right now i just want to get this thing together before summer...
I want to thank everyone on here for all the help and guidence...
#47
I think it's a good idea as well to add the aftermarket hi-perf exhaust. You will most likely see an increase in RPM and might pick up about 1 MPH----MAYBE! The new exhaust will give your engines a much better appearance and they will give you a more thunderous, racey sound that we all like.
Stainless Marine is a good hi-perf manifold type of exhaust system. They will last longer than the Lightning headers, but won't make as much power as the Lightning headers will. The Stainless Marine exhausts are reasonably priced as well. I think you'd be happy with either brand. Which ever you choose, put them on and go boating this summer and save the upgrades for the winter. Have fun!
#49
I would agree with KAAMA
The 330 exhaust port has a venturi diameter of 1.5 inches. The valve lift is Im' guessing under .500 making a small window area. Between these two, you have a choke point. I dont think adding exhaust will help without a decent flowing exhaust port.
