Bravo Gimball
you do not need to take it off. drill holes in the side of the assembly to get to the nut. the gimbal ring is fine i am sure. you need a new pin and bushing.
have fun
Treadwell
have fun
Treadwell
It looks like I will drill the side of the housing.
Treadwell, why do you not think the ring is bad? Are the pins/bushings known for going bad first? Is there aftermarket stuff that I should look at or stay w/ the Merc parts?
B-MAX REPAIR
call me 216-390-1330 RON BENDER WE REPAIR GIMBAL RINGS & ALSO MAKE SWIVEL SHAFTS OUT OF 17-4 STAINLESS,CORROSITION RESTANCE MATERIAL.I CAN SAVE YOU TIME IN REMOVEING & INSTALLING YOUR SVIVEL SHAFT WITH A KIT WE MAKE. CHECK OUR WEB SIGHT AT WWW.JRMARINE.COM CLICK ON GIMBAL REPAIR.
rslick
13
06-15-2005 11:54 PM
