Bezel for gaffrig mechanical trim tab indicators?
Does anyone know of bezels that can be put under the gaffrig mechanical trim tab indicators? I'm replacing my boat leveler trim tabs with kplanes and my mechanical indicator is going over the location where the old electronic indicator used to be. The only problem is that the circle diameter of the old gauge is just a little larger (1/8") than the width of my new gaffrig gauge. Any suggestions? I really don't want to do any fiberglass and gelcoat work. Thanks in advance.
Allen
Allen
don't know of an existing product, but you could find a local lazer cutting manufacturer to cut arectangular bezel out of stainless per your dimensions and then have it buffed, or cut out of aluminum and have it annodized a color.
i am imagining a thin picture frame shaped bezel
just two alternatives
Charter Member #232
Hit their web site I am sure you will see them. If not call them up and get the catallog
Jon
Jon
Put your best foot forward!
