Metal In Oil
Charter Member #655
I had two of my main's down to the Brass ran great! never knocked a bit ....hows your oil pressure?
If your boat has a sail do you ride a horse to the ramp?
No Noise Here Either
Just a bad bearing, ruined crank and cracked block!!! Engine ran great and strong. I just noticed a little oil in the bilge.
Pull the motor before an inexpensive issue turns into a complete
rebuild with new block like mine!!!
As already stated I would check the distributor gear before I tore the whole engine down If its not a brass gear then just call me when it breaks because I will be the only other crazy ****er out on the lake on a stormy day
Dont forget about me, Ill probably be there too. Probably broke down too though. I hope it isnt too serious. Dist gear, valve guide, bearings, cam gear thrust washer, thats about all I can think of thats brass looking.
Dyno, oil pressures good.
Bobby: No, I run H.S. rockers. The filter was clean.
Thrillseeker, and Formula 31 Keep your eye out for me my boat will look like this.
Just once
Pull that motor & drop the pan and be sure.
I just bought a HP 500 motor that had been rebuilt, oil pressure was great for a short period & started dropping slowly. Within 1 hour max I spun a bearing on # 6 rod. I still had 20' of pressure at 1000rpm before I pulled the pan. I am gonna pull the rest of the caps tomorrow. Check it for peace of mind & save yourself $$$
Iam not looking forward to starting all over again plus I just blew a couple $$$ and never had any fun doing it!
