msd box
Official OSO boat whore
Don't worry about the box. It's fully potted so there is no risk of sparking.
Ya. I have used a regular 6a as well. The only difference is color of the box and the connections. They have 3 rubber rings that act as gaskets for the connections.
DAVE
DAVE
I was concerned, like you, about the 6AL...
I called MSD direct and they told me that while the unit was internally covered completely in resin, the connections inside are not. This will cause corrosion internally and eventually failure. Their suggestion was to seal the basic wire openings, yet leave the riveted side down for water drainage. Sealing it completely would hold the moisture inside causing more corrosion.
My concern, in the event of failure, is you can't see how bad the connection are getting and replace them before they fail... You will be stuck with our pants down.
My problem will be replacing it for $500+ (unit and rev limiter). Wait and be stuck or replace it when the budget will allow it????
Looking for advice also....
Red Racer
Red Racer
