Anybody know of a good place to buy Holley marine carbs?
![Question](/forums/images/icons/icon5.gif)
Does anybody know of a good place to buy Holley marine carbs, probably 750s? I have had it with my stock Weber carbs. You have to pump the throttle over 100 times to start the engines after sitting for a week - been that way since new. Thanks.
Cheif engines. #9022, 800cfm double pumper(marine)
$400.00...
Just looked, a 750cfm is $410.55
Never seen any cheaper, and there really nice to deal with.
Summits are $453 for the #9022.
$400.00...
I have a Holley 750cfm, marine carb, dual feed, mech secondarys
Really used for about 25 hours and went to bigger carb.
$200.00 with a small K&N Filter
Sheikman
Cleaning out the basement of parts
Sheikman
man save that money run auto holleys they work fine just don't tell them their on a boat they will never know
really if you need the down turned vent tubes just swap them or run a rubber tube from one vent to the other and cut a hole in the middle over the center of carb opening
but I would not worry about it
Sheikman, I may be interested in your carb if BajaBuddy is not interested. I to have the great Weber which at the start of the season would never start without the aid of starting fluid. I simply can't believe Mercruiser ever went with these carbs! What a pain in the behind! On the auto carb, I did have a 750 Holly on my Scarab with no problems. By the way what did the 750 come off of and how old is it??
