Promax 300 w/SVS & High Flow Reed Plate = preliminary results >
Old 05-17-2003, 05:36 PM
Default Promax 300 w/SVS & High Flow Reed Plate = preliminary results
Hi!!
Got the boat on water yesterday. It is a Phantom 25 w/Promax 300 1999 model w/SVS & High Flow Reed Plate. The boat weight is approx. 1.050 kilos incl. engine and driver.
The conditions was not ideal, but we managed to squeeze 77,0 mph out of the rig at 6.150 rpms. Normally in those conditions and in this area (Grimstad, where my dealer is located), we get 74-75 mph at 5.950-6.000 rpms. So I presumee we gained 150-200 rpms.
The fjord in Grimstad is relativ short, so you have to make a slight right turn after approx. 1.200 meters. And the turn slows you down.
I will check the speed on a another fjord where I normally get the best consistent speed (75-76 mph at 6.000 rpms), and let you know. This fjord is 10.000 meters long and conditions are normally great.
The best speed I have got is 78 mph at 6.100 rpms, but thats only once a year (in the spring). Heaven knows how it happens. Its just there.
We have doublechecked that the SVS is all up when the butterflies are fully open. The tps is set to 4.02 V using a digital voltmeter. Reccommended tps is 3,8 +- 0,25 V. Should we set the tps on the low side or as now - on the high side?
Any point of recurving the ecu? The EFI injectors are blueprinted and calibrated (excellent and all within 0,4%).
Since it is still very cold in Norway. Merely 8 degrees celcius in the water, and 12-14 Celcius in the air, the engine is running very cold. I get 145 F at idle, but at 4000 rpms + the temp drops to less than 115F. Which is too low. The termostats are all fine.
We have made a adjustable poppetvalve two years ago, and we can restrict the flow of cold water. However, the psi raises to more than 25 psi at wot (which is max reccommended psi), so we end up running too cold now anyway. I will plug one of the waterinlets to see if it helps.
When running too cold, I presume the engine does not make full horsepower - or am I wrong?
I look forward to hearing back from you.
Cheers, Toffen
Toffen is offline
Old 05-17-2003, 09:10 PM
RLW
Hey Toffen,
Thanks for the report on your rig. I would think that there is an optimum temperature range to maximize your performance. You've got some pretty good numbers coming out of that boat.
What prop are you running and what is your setback dimension? Let's see some pictures!
Russ
RLW is offline
Old 05-17-2003, 09:48 PM
Russ; I know Canadice is still cold, but, just what the heck do you know about Norway??! --- JPC
jpclear is offline
Old 05-18-2003, 04:52 AM
Default Promax 300 v/SVS & High Flow Reed Plate
Hi!
I am running a blueprinted Tempest A47 26 pitch prop. I have tried various props such as Spinnelli DR4 27, Chopper II 26, Laser II 25, Thurbo Lightning 26, etc, etc. But the Tempest is the fastest and has best crusing speed as well (52 mph at 4.000 rpms and 60 at 4.500 rpms - 1.75 gears).
I use a CMC 5,5 powerlift + 2 inch spacer. Have tried more setback, but the boat did not work in high seas with this despite bowtank.
The bottom is blueprinted as well (straight and sharp), and I have watersanded it with 600 grit paper.
I have also rebalanced the boat.
Any ideas?
Cheers, Toffen G
Toffen is offline
Old 05-18-2003, 05:14 AM
Hi there fun to other norwegians in this forum, too.
I live in Arendal and thats not far form grimstad... 10-15 nautical miles or so..
cobra860 is offline
Old 05-18-2003, 02:32 PM
Toffen2
Hi!
Here is a picture.
Cheers, Toffen G
Attached Thumbnails Promax 300 w/SVS & High Flow Reed Plate = preliminary results-toffen-brygga-.jpg
tj309
0
03-14-2005 08:11 PM
Toffen
05-19-2003 04:40 PM
Toffen
0
02-02-2003 02:17 PM
Toffen
1
01-02-2003 03:30 PM
Toffen
01-01-2003 09:22 AM
Quick Reply: Promax 300 w/SVS & High Flow Reed Plate = preliminary results
