Broken Skeg On Drive
A friends boat with twins, has the skeg on the starboard drive broken off at an angle upwards from the bottom of the skeg. About 3" of skeg is missing ( across the entire width of the skeg ), still lots left, but he asked if this was dangerous or could cause handeling issues or problems ? There is a tie bar between the drives, and the port drive skeg is fine.
Both drives are fine operational wise, as are the props.No damage. He bought the boat this way.....
I know you can have the lower section of the drive removed, and a new skeg welded on. Thats what I told him to do. He though one of those "Skeg Protectors" would be a temp fix. I advised didnt know enough to make a sound comment as to potential issues either way. Its on a 38' Sonic
What do you guys think ?
