Wiring question?
Wiring question?
I'm putting a pair of HP500's together and when I marked all the wires before disassembly I missed a couple of wires. They are paired together one is red w/white stripe and the other is white w/green stripe they both go into the ignition module and the other ends have crimped ring connectors and are near the oil pressure switch on the oil filter housing and also near the coil but I'm not sure where they go.
Also does anyone know which oil port the oil temp sensor goes to on a Gen V block?
I wish I had one of those installation manuals that you are suppose get with new engines it shows wiring diagrams and other good stuff anyone want to sell one for HP500 carbs?gofastpilot
Charter Member #30
I just looked in my manual and it shows the same as the above diagram for the distributer on the HP 500 carb.
I have Steps & Bubbles!
