Removing Vinyl Graphics >
Old 06-03-2003, 10:41 AM
Dave M's Avatar
Default Removing Vinyl Graphics
What is the best way to remove vinyl graphics?
I have heard people us a hair dryer or heat gun.
How about some type of solvent?
Dave M.
Dave M is offline
Old 06-03-2003, 11:16 AM
Charter Member #139 /Moderator/Platinum Member
klaw's Avatar
I have had good luck with a hair dryer
klaw is offline
Old 06-03-2003, 11:19 AM
SSComp's Avatar
I used a heat gun with grat results. Be prepared to wet sand the gelcoat if they have been there for a while
SSComp is offline
jr
There is a product that 3m makes. Its called woodgrain remover. That may not be the exact name. Thay make it for removing the hideous woodgrain panel graphics on mini vans. I used it on some pin striping and it worked great. It was recommended to me by a boat detailer.
I found it at Napa.
Old 06-03-2003, 11:59 AM
Andrea
Used with good luck a hairdryer on the warm position (use a difussor that concentrates the airflow) and try to help to remove the vinyl adhesive with windex or similar (glass cleaner).
If some residues of adhesive gets on the surface, rub with isopropyl alcohol to remove the gum.
Old 06-03-2003, 12:21 PM
Heat gun and Goo Gone works great
BOATMAN572 is offline
Old 06-03-2003, 12:47 PM
Dave M's Avatar
Thanks everybody. I love these no cost fixes!
Dave M is offline
Old 06-03-2003, 10:16 PM
Back4More's Avatar
Heat gun and whatever glue is left...WD40 will get it off
Back4More is offline
thedonz
07-11-2014 07:15 PM
thehip
Fiberglass and Paint
13
11-04-2007 06:24 AM
Fast 1
01-02-2006 10:36 AM
Dago Racing
Fountain
27
09-06-2005 08:47 AM
Cattitude
17
08-04-2004 09:57 PM
Quick Reply: Removing Vinyl Graphics
