prop question bravo1 vs mirage plus?
Originally posted by 26sonic
guys is it possible to tweak a bravo 1 prop to get a little more bow lift ? with out sacrificing other gains from this prop?
Houston Prop did the work. My X-dim is TOO high and I really haven't seen all the benefits yet. Still can't get enough bow lift, but the prop changes helped. The prop does stay hooked up better with more trim and will stay on plane at lower rpms.
I'm lowering the drive an inch this week so hopefully that will help.
I just switched from a mirage 23 p to a Bravo 1 22 p but with great results. Much better hole shot, better cruise speed at lower RPM's and top end remained the same. However with the Mirage I spun at 4600 RPM and the B1 at 5000. I've been told these are marked on the high side for pitch. That the 22 B1 is really more like a 20-21. Sounds like you need to go down in pitch.
