HP500 + Wipple Supercharger =Reliability???
![Question](/forums/images/icons/icon5.gif)
I'd like to know how well HP500'S with Wipplechargers
are holding up?
Hours,Problems,etc???
Also what other than the Wipplecharger kit needs to be installed to make this setup complete?
I have HP500'S with cnc Brodix heads,Crane 139631 cam,and a 750 cfm Holley carb that flows out at 830cfm.
Will I have difficulty setting up the engine with Wipplechargers myself or would putting the engines on a dyno be the best route?
Thanks,
Dennis
are holding up?
Thanks,
Dennis
Dennis I've done alot of whipples and the set up you have sounds fine I always add felpro head gaskets ,innconel exhaust valves and they run for ever !! the cam is alittle small but will work fine ,,the boat will be very fast and you don't need a dyno ,,do go with a 4500 holley if you get the kit I would 830 is tiny with the blower ,you can do it your self its a complete kit ,,p.m.me any questions
