Power steering Pump
![Question](/forums/images/icons/icon5.gif)
Lost my Hydraulic return line to the Power steering pump & ran with without much fluid as I limped home. Running this pump without Fluid???Do I need a new pump? It did squeak a little and that went away after refilling. What damage could have been done, If any??
Thanks John
Thanks John
I had a steering problem on the new boat I purchased, pulled to the left out of the hole. Changed all fliuds except PS after purchase. After 10hr, found the oil cooler leaking water and when I pulled it to fix, I noticed no PS fluid came out and then I noticed the pump dry and a bone. Put fluid in and it made some noises until the fluid was full and have been running for 10hr and still going strong.....AND, it doesn't even pull to the left any more..
