Bravo drive has Neutral and Forward, no reverse.
Charter Member #1171
If none of that works,,, flip part #8 over as it sometimes wears after time. It will get you by for a biut but plan on changing it if it helps.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
Charter Member #655
I've got one drive that goes into reverse hard too! if I idle it up a little it drops in?????
If your boat has a sail do you ride a horse to the ramp?
dyno, the shifter cable running from the engine to the outdrive is not adjusted correctly. If I recall the adjuster nut will need to be moved to towards the outdrive. I had the same thing over the weekend and had to adjust mine.
Brian
Brian
Charter Member #30
Dyno,
That was my problem and I did have a little luck with adjustment for a couple of weeks but finally had to replace the parts I mentioned above!
I have Steps & Bubbles!
