Insta Trim, Leaking
One of my trim tabs seems to be leaking. It will not hold a down position and the oil level has been depleated. Outside, it appears as if it is leaking where the hose connects to the cylinder. Can this typically be repaired with a new hose and reconnecting or does the entire cylinder need to be replaced.
I hate the winter!!
I had the same problem happen on a friends boat. The clamps that insta-trim uses are junk. They typically come off. Just cut the remaining clamps off and use stainless steel hose clamps.
I didnt notice a clamp outside of the boat, where the hose enters the hydro cylinder. Overtons sells the complete system, can you just buy one cylinder? I will call Insta trim today.
There is a piece of trim that hides the clamp just above the cylinder. It should slide up but will probably take some effort if it's been there a while. You can buy parts including a single cylinder from Boat Leveler direct. I replaced a cylinder, my pump, and installed larger tabs for about $200. I think they get $30-$40 for a cylinder.
they have a good web site, here is a picture of the assy
I need to look at my boat closer and determine where the leak is before I buy any parts. Im not sure if it is at the cylinder or at the hose-to-cylinder.
