How much oil should 502's burn?
I found that the half quart from full to half went very fast. From half to add it took much longer. I did try the 40 wt. Valvoline and it did not burn as much but I am sticking with the 20-50 Mobil 1. I think that operating temp has a lot to do with it.
Team Dysfunctional
I got 20 hours on her this year. I cruse at 3700-4100 and ran one poker run. I havent lost a ounce
.........................................Yet
![Stick Out Tongue](/forums/images/smilies/tongue.gif)
To cruise a Formula 400 @ over 40 mph probably takes a reasonably high RPM. My experience has always been that the higher the RPM, the higher the oil use. I cruise at 3500 @ 52 MPH and seldom if ever add oil. I use Mobil One 15-50 and keep it very fresh with 25 hr change intervals.
32' SUNSATION
I use to burn about a quart every 5-10 hrs or so, But now with ever oil change, I throw in a quart of Vaseline.![Big Grin](/forums/images/smilies/biggrin.gif)
Just kidding guys, Don't throw Vaseline in your engine...![Smilie](/forums/images/smilies/smile.gif)
I ear when you do lose some it's more than an once!
IMOA if you change oil brands or type ((like going to syn.)) sometimetimes the new additive package will cause the motor to use oil a short time then stop ,Syn. is better at lasting as its harder to burn and ron above is right forged piston motors are prone to us alittle oil . J&E piston that come in 502's use a tighter clerance and thats a big reason Merc uses them they really make a good part ( thats why most cup teams run the J&E's is the clearance issue,tight and very tough ))
See Ya
See Ya
