Ive Hadit With Crane Cams
Break in on a flat tappet is critical!!
Spring pressure is critical and too much will wipe out any flat tappet cam in a hurry. Proper pre-lube of the cam is also critical. I also strongly recommend using GM EOS (Engine Oil Suppliment) available from any General Motors dealer-this helps more than you can imagine!!
