cam size suggestions?
IVE HAD BAD LUCK WITH CRANE LOOKING TO GO WITH ISKY CAMS
ANY SUGGESTIONS WHAT SIZE CAM? FLAT TAPPET (HYD)
FOR A BIG BLOCK 454 ORIGINAL 365 MAG WITH GOOD ROD BOLTS, MANLEY VALVES, PERFORMER INTAKE & 750 OLLEYS
I like the Isky 284/292 mega cam on a 112* lobe center it has to be custom ground but a very good cam and we have used alot of them and should have 2 or 3 in stock ,it works better as you know with pocket ported heads with a good valve job ,but that cam is a monster
![Wink](/forums/images/smilies/wink.gif)
