alpha question . . again . .
Neno the mind boggler
thanks scott . . let me know (cell# 419-461-1484). was thinking about getting this wraped up by the LEOPA poker run. dont know if im giong to get a batboat or run mine so i wanna be ready just in case. later.
![Cool](/forums/images/smilies/cool.gif)
08 OPA High Points Champion
To clarify my statement,
once the l/h rotation lower is installed,
the shift cable will have to be switched
at the quadrant, so the shifters match
direction.
L/h alpha lowers , the rear gear is the
forward gear, which is the reverse
gear in r/h alpha's, thus requiring
different cable action.
jt
direction.
jt
thanks jt . . .
Charter Member #30
Answer your phone
And TTT for anyone else that can help My friend did not have counter rotating drives in stock.
I have Steps & Bubbles!
glassdave,
I switched alpha's to c/r. PM me if you like
I have just bought a set of Alpha drives. One is supposed to be a CR unit but is not marked. With the shift tab in the straight position, they both turn in the same direction. I may have gotten screwed. Jt mentioned that the cables must be switched. If so I might have one CR unit. Should I split the upper and lower and start there?
thanks for all the info guys.
sutphil - i will contact you. i would definetly like to discuss this with someone that has been through it.
scott- i'll get ahold of you or see ya at the poker run.
BahaRunner- you weasel
. . start yer own damn thread . . .
![Stick Out Tongue](/forums/images/smilies/tongue.gif)
![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
