Oil Pressure Gauge off the scale??
Yesterday when we came off the lake I noticed my Oil pressure gauge was off the scale on the high side of the readings. Would this be a ground or a sending unit problem?? I did remove the dash and check for a loose connection but turned up nothing. Any ideas??
The sending unit is a small round canister about 2" in diameter and 2" deep that screws into a fitting on the block. Not sure if they are all located in the same place on all engines, but mine is just below and behind the #7 spark plug. Mine was doing the same thing and it was the sender. 15 minute job to change it.
Waterfoul
06-15-2003 08:18 PM
