Merc water pressure relief valve >
Old 08-09-2004, 12:05 PM
Default Re: Merc water pressure relief valve
My pressure was pinned at 35, after installed not over 25 and after removing the thermostat no water pressure.Waters 120 and oil temp takes awhile to come up to operating temp.Looking to install oil thermostats now.
z.zuperboat is offline
Old 08-09-2004, 01:50 PM
Nordicflame's Avatar
Direction is "either"
Make sure you put it just before the crossover so that you don't loose good water flow to your oil and PS coolers. If you put it before the coolers the cooling capacity of the coolers will diminish greatly.
Nordicflame is offline
Old 08-09-2004, 11:16 PM
Ginger or Mary Ann?
US1 Fountain's Avatar
Originally Posted by Faster!
I put mine between the sea water pump and crossover.
Where did you dump the water?
US1 Fountain is offline
Old 08-10-2004, 06:04 AM
Canada Jeff's Avatar
This is what I'm afriad of! so after the coolers, before engine block sounds about right.
Canada Jeff is offline
Old 08-10-2004, 06:18 AM
Faster!
I am dumping to an existing thru hull that I had for a manual bilge pump. Will be cutting in a new thru hull this week.
Yes put it in after the coolers. Merc sends a little instruction sheet along with the part and they recommend after the cooler.
Old 08-10-2004, 08:30 AM
Must use a full 1" dump.
I dump mine right on top of the outdrive
Old 04-26-2008, 07:30 PM
Charter Member#330
MrCIG's Avatar
TTT For Bad Medicine
MrCIG is offline
Old 04-27-2008, 08:54 AM
Originally Posted by klaw
I know this topic has been long and a few guys have made there own water dump systems with the one now available from merc for about $100 has any one used these looks like a nice package
Merc
Water pressure relief valve
863208a3
I am about to buy a couple
What is the current cost for the relief valve? Best place to purchase?
ROTAX454 is offline
Old 04-27-2008, 09:45 AM
Charter Member #601
Mr Gadgets's Avatar
Bam has it for $275. Lot of money for plastic..
Is there decent alternative out there?
Mr Gadgets is offline
Old 04-27-2008, 02:05 PM
Elite Marine's Avatar
[QUOTE=Mr Gadgets;2539601]Bam has it for $275. Lot of money for plastic..
QUOTE]
Agreed, but whats your engine worth?
Elite Marine is offline
Quick Reply: Merc water pressure relief valve
