Mercruiser Wiring Diagram-Starter
Does anyone have a wiring diagram for what colored wires go where on the starter/solenoid? I've got a Gen V 502MPI if it matters. I am heading to the boat tonight and want to make sure I'm looking at the correct stuff. Anyone ever blow that weird looking 90A fuse on the starter? I think I did but will find out for sure tonight.
If I did blow that fuse, where do I find another? It doesn't appear to be a "normal" fuse and on mercruiserparts.com it's called a "fuse assembly".
Thanks in advance,
Dave
Thanks in advance,
Dave
Try this- there are several wiring diagrams that may help. There is usually some type of fusible link at the beginning of the hot feed to the fuse panel and starter switch to protect the wire.
http://www.marinemechanic.com/Workhorse/index.htm
Good Luck!
Bulldog aka Ronnie
Good Luck!
Bulldog aka Ronnie
