What's the right size carb.
I have a 502 gil dry pipes, waterpump crossover, Msd box, roughly 600 lift cam full roller valve train Dart intake and now the thing in question a 1050 dominator. I was told 600 hp which I believe to be more acurate at the 525or so range. I as well as some others belive I'm overcarbed. So the question is what size and what# jets would be a good starting point If anyone sees me going down the canal I'm not really crying it's just running rich.
Sounds like your engine is built to the same specs as a Mercruiser 500 HP. They use an 800CFM marine Holley carb with pretty good results. I can't recall, off the top of my head, the jetting, but you can look it up in a Mercruiser HP service manual. That would put you right in the ball park first time out.
Dennis Moore
Dennis Moore
Merc uses satggered jetting with different jets in every hole.
I had an 800 on my 454 and it was jetted with 78's+/- in the primaries and 94's +/- in the secondaries with no secondary PV and a 6.5 front. Can't remember the exact sizes I ended up with, but they are within 1-2 sizes of those.
A good formula to use is cubic inches times MAX RPM divided by 3456.
Now that is if your engine is running at 100% volumetric efficiency. Supercharged engine will run in the mid to high 90s VE and normally aspirated engines will run high 80 to low 90s VE.
Roby
Roby
