LWP replacement options??
Re: LWP replacement options??
Ok I have a transom pick up and a high mounted sea strainer ( the only place it will fit on my checkmate 251) i have no problem with this set up. pressure is good and temp is steady at all speeds. I did not install it it was on the boat when i got it. I have never seen this transom pick up before the strainer is MM.
P.S. got a new set of white SS comp gauges for Xmas for the old check.
jafo
09-23-2002 10:00 PM
