Drive alignment
Drive alignment
I have a 84 Formula 302 454's with King Cobra outdrives. My problem is that the boat will list to the port side at speeds below 45 mph. If I use my trim tab at 3 or about 25% the boat will level itself but feels funny to steer. Also the boat wants to pull to the left slightly. The bottom of the boat is in mint condition no hook with straight chines. I suspect that the drives are at fault but since I have only had a single drive in the past I have no idea of where to start with aligment?
Does the boat sit level in the water at rest?
Any chance one prop is different than the other.
If the boat sits level at rest then one prop is getting cleaner water or is causing more transom lift.
Toxic FORMULA
Are your trim indicators correct? One drive could be trimmed higher than the other , causing you problem , yet on the dash the indicators could read the same
Another answer...just keep it above 45
Boat sits level,with both trim tabs up(the chrome piston on both tabs being equal in length) the boat lists to the right at speed below 45. Props same,and undamaged.How much toe out or in do I start with?
Andy I've been told that you should have about 1/2 of toe in . By that I mean that center of the prop shafts should be !/2 inch farther apart that the center of the nose cone. Hope that helps. Rick G.
