broken engine
broken engine
was running 4500rpm when boat started slowing down. looked at gauges and port motor rpm were dropping fast .motor stalled. cranked back up but not easily.took off, got on plane to 3500rpm and it did the same thing. tried to start it dut it would not turn over. let it sit an hour and it fired up and reved fine in neutral. shut it off and checked oil. nothing but milk.pulled plugs and they all look fine.boat has 160 hours fresh water.motors are hp450's. exhaust manifolds .blown head gasket,or what.how is water getting past rings to the bottom?how do i check exhaust to find out if they have a hole?
okay planning a leak down and comp. test this weekend but i know ive got a leak. how are they going to tell me what is leaking other than which cylinder. would rather not pull motor if not nessasary.hoping its contained to top end but how will i know if i bent a rod trying to compress water?
You also need to check the intake manifold gaskets for leaks at the front and rear water passages. A problem there wil dump plenty of water in the oil.
Good Luck
Bulldog
Good Luck
Bulldog
Re: broken engine
Ronald,
What ever came of this repair? Did it end up being something major? If so, was the whole engine gone through or were just the damaged parts replaced.
I just happened to be goofing around on OSO tonight and came across this thread about your boat.
PS...Were you able to get the drive repaired from your misfortune a couple weekends ago?
Buck
Buck
timucin
09-14-2003 10:52 AM
