Big Block Vortec heads airflow data...?
7.4MPI to Intake & Carb, with ZZ502 Cam
Hey DonMan,
I'm am considering going down the road you had planned before your 454 went away.
454
L-29 Heads
9:1
800 cfm Holley
RPM Airgap
ZZ502 Cam
Thanks!
454
L-29 Heads
9:1
800 cfm Holley
RPM Airgap
ZZ502 Cam
Thanks!
Patrick
Patrick
MarineKinetics
Flow for 049s
lift I E E with pipe
.050 37 24 24
.100 59 52 52
.200 124 96 98
.300 188 123 128
.400 232 143 152
.500 250 166 177
.600 264 173 187
.700 264 174 192
.800 265 173 192
If you still need the Merlin # I can find them also.
I had a zip file with hundreds of cam, head, and .dyn #s for DD 2000 including some marine cam profiles, Ill see if I can find them.
Hope this helps
Bob
.050 37 24 24
.100 59 52 52
.200 124 96 98
.300 188 123 128
.400 232 143 152
.500 250 166 177
.600 264 173 187
.700 264 174 192
.800 265 173 192
Hope this helps
Bob
The link listed in the second post gives plenty of data for heads. They just don`t have any data for the L29 Vortec heads. Most people I`ve spoke with tell me to use numbers in between the 049 heads and Merlins.
It would read something like this:
VALVE LIFT INT EXH
.100 65 51
.200 135 99
.300 197 128
.400 238 153
.500 259 171
.600 272 179
Guess I answered by own question...
VALVE LIFT INT EXH
.100 65 51
.200 135 99
.300 197 128
.400 238 153
.500 259 171
.600 272 179
Pat, Im running ZZ502's in my boat, and I tried to build these motors on desktop dyno, but GM doesnt give enough info on the cams to get a accurate #. Crane gives you all the open and close degree info which is more accurate for the program. I plan on rebuilds this winter with cam upgrades, so if you want to buy the ZZ cams and lifters let me know.
DonMan, I haven't been on for a while, but just read about you scattering your 454. I put a Vortec 454 long block in my boat over the winter - it was one piece rear main seal, roller hydraulic unit, late model truck take out - got it off one of my Buds, and I think he has another one. I put a B&M 177 blower on mine, with a Predator on top of that - all I can say is it is a torque monster!!! If Ken still has the other one, I gave him $1400 for mine, pulled a couple of caps & it didn't look like it had been run, and the cylinders still had visible crosshatch below the pistons, and no carbon, very little suit in exhaust ports - Just a thought. Also, those Vortec 454 heads are closed chamber and build compression with flat top pistons (~100CC chambers, I have been told) I am being awful careful on the spark advance and liberal on the octane with my blower (8# max boost) but I was very impressed with the condition of this and the other motor he had (has?) Let me know if you want me to check into it for you - easiest to contact me [email protected] because I don't look at this very often -
Neil
Neil
Be careful with a blower on a L-29. I have been told that the heart shaped chamber will burn up pistons with the extra boost.
Whipple took their package for these engines off the market...
Patrick
Patrick
Re: Big Block Vortec heads airflow data...?
Ok -Title this experience is the best teacher, or maybe unlimited lessons from a limited check book! L-29's and blowers didn't mix. At least none of the shrapnel went through the hull! After I put it back together, I put a tunnel ram and two Holley's on - that worked a little better - but suffered from fuel delivery and high speed lean conditions (not conducive to longevity either). At least none of the shrapnel went through the hull! Now, on my third L-29 (This lesson is getting expensive, so read carefully) ( I probably should be punished for what I have done to so much beautiful big block metal) I am running a BG demon 850 on a sungle plane Holley manifold with the ZZ502 cam (I would recommend the ZZ cam to anyone running rollers just for the sound alone!) but it makes such beautiful TORQUE, with outrageous amounts of midrange to 5500 RUSH! I have it on a Berkley 12JE Pump with a 2A impeller. According to Berkley's charts for the 2A impeller, twisting it to 5500 RPM is making 550+ ponies (the chart ends, but if you extend the lines, it would be at or above where 600 line should be on the graph. According to Berkley, this is a relatively good approximate dyno, as the pump loads the same running 80 or tied up to the dock. This is NET, running alternator, K&N Filter (sitting on an 8" tall velocity stack), and baffle plates in the headers! Minor port matching of the manifold to heads, 1 1/4" aluminum spacer under the carb, with 1/2" phenolic between that and the manifold. Wow, why didn't I just use this old tried and true recommended set up on the L29 headed Gen VI in the first place?
BTW, Ignition is mallory billet distributor, Mallory digital 6A box, Promaster coil, static timing at 14 BTC. Pump 91 octane and no rattles. I have also added a set of roller rockers, (just because they were there). It will probably take me the rest of my life to get my VISA card paid off!
Re: HEADS
Originally Posted by j winkelman
ARE THE 049 MERLINS A RECTANGLE HEAD ?I DON'T HAVE A BOOK IN FRONT OF ME TO SEE IT'S A PART#
