Latham Steering Fittings Split?!!! >
Old 09-15-2003, 07:13 AM
Jana's Avatar
Question Latham Steering Fittings Split?!!!
Got my boat back after the engine rebuild a couple of weeks ago and went out for only 2 hours. Came back and found hydraulic oil all over my bilge. One of the bronze fittings in the steering system on the inside of the transom had split. Marina did a half-baked fix, but it's not leaking. Went out again Saturday and another fitting split. The system worked perfectly before they pulled, rebuilt and reinstalled my motor. Would love some clues about what may be causing this before I go down to "discuss" this with them.
Jana is offline
Old 09-15-2003, 09:09 AM
Offshoreonly Advertiser
Mbam's Avatar
Post a picture of the failed fitting
Mbam is offline
Old 09-15-2003, 12:00 PM
Jana's Avatar
Sorry, no digital camera. All I can say is they both split parallel to the hose, as if along a seam. It seems to me like there's too much pressure in the system somehow, but I defer to the experts.
Jana is offline
Old 09-15-2003, 10:05 PM
1_bigdogg
hard to tell ...which fittings were they?...hose ends..90's....different fittings in there that can go bad. where are they located?
Old 09-15-2003, 10:54 PM
candyman35's Avatar
Jana,
See if you can get someone to take a picture of the fittings. I'd also give Latham a call and ask them. They have great customer service. 954-462-3055 Things wear out and break but it does seam suspicious it's right after the rebuild. Let us know what happens. I have Latham steering also and would like to know what to keep a look out for.
Dan
candyman35 is offline
Old 09-16-2003, 06:53 AM
Jana's Avatar
I'm going to call Latham this morning.
Also, forgot to mention that the first time I went out I found a brass fitting on my cockpit carpet that looks like it's from the steering system. One end is hex outside with internal threads (about 5/8 diameter) and the other end has external threads and a little hole in the end that can't be more than 3/16 diameter. It looks like some sort of nozzle.
The first fitting that split was one of the hose ends at the transom. The second was a hose end that's up under the deck.
Jana is offline
Old 09-16-2003, 07:16 AM
Charter Member #30
Scott's Avatar
Sounds like the restricter that screws into the pump on the high pressure side. I wonder if they had a hard time finding the fitting that should screw into the piece you just described and decided to not use it
I am sure someone who understands Hydraulics can explain what would happen without it,if anything
I have Steps & Bubbles!
Scott is offline
Old 09-16-2003, 06:25 PM
mcollinstn's Avatar
Possibility #1.
Pulled the drive to be able to remove the motor. They may have left the steering cylinders hanging in a weird position that kinked the line.
Without pictures, though, it is difficult to know whether you are talking about a split in a stainless hose crimp jacket or in an actual machined fitting piece...
mcollinstn is offline
Old 09-16-2003, 08:33 PM
1_bigdogg
Sounds like some split hose ends......if they are the 3 piece reusable type, they may have been installed incorrectly from the begining. Are they from the same line? Also the fitting you described sounds just like what Scott said. The only problem I see here is that there is really no way to put the original pressure line back on the pump without it(unless they got real creative).
Old 09-17-2003, 06:53 AM
Jana's Avatar
No. One each in two lines. I'm probably going down there today, so I'll see what's what at the pump. (After the hose clamps on the split fitting, I wouldn't put it past them to have gotten creative.)
mcollinstn - it's brass fittings inside the boat, and yes, I think it's in the crimped part.
Latham's answer was that it could be many things. They said check to be sure the system was bled properly and also check the filter (may be clogged or collapsed). The piece I found didn't really ring a bell.
Jana is offline
Quick Reply: Latham Steering Fittings Split?!!!
