500efi troubles
Swap the ECM's from side to side,
see if the idle condition follows the
ECM
just a thoought.
jt
ECM
just a thoought.
jt
I have a pair if 1999 500hp's (carb). The alarms go off after a hard run, then quiet after a couple minutes at idle. Both engines do it. All gauges show normal, and drive bottles are full. I'm stumped! I unplugged the drive bottles....didn't help.
What now???
Help?
What now???
Help?
Offshore Cowboy
Originally Posted by John B
My outdrive oil level did this. The level was going down at upper rpm. I just filled it to the max and it went away!
i'm not a mechanic, so hopefully my "non-techie" comments were understood.
Offshore Cowboy
What now???
Help?
What now???
Help?
if not, unplut each of the three sensors to narrow the scope of your problem. i'd bet your senders or connection(s) to senders are bad.
Offshore Cowboy
What now???
Help?
What now???
Help?
Offshore Cowboy
What now???
Help?
What now???
Help?
