Do bravo props fit Alpha drives?????
Team Dysfunctional
![Post](/forums/images/icons/icon1.gif)
If it aint broke .... I can break it....
speel chekk this fokker!
depends on teh alpha i believe.
I have an old alpha and have been told that the 4 blade bravos are just to big. The diameter of the prop is bigger than the mirage+ 3 bladers. The mirage just barely clears the cavitation plate.
Pardon me, while I whip this out!
You can run up to a 15 1/4" dia. on an Alpha1- it will barely clear the cavitation plate. If you run a Bravo One four-blade on an Alpha however, get your check book out. It puts too much load on it, and you WILL replace your drive. Know those who tried it, and same result every time.
Stick with the REV4 if you have to run a 4-blade on an Alpha.
dj_merk_e
Scarab
0
09-07-2007 07:48 PM
